Installation problem
Message 1 of 28
Today I downloaded the new version of Fusion 360. I have logged in with my user and I get the message "hub configuration has failed." I tried to reboot, install new ... nothing.
Using a MacPro 2008 with OSX 10.8.4
Fabio
Replies (27)
Message 2 of 28
Spolarts
Same problem here....
Message 3 of 28
innovatenate
Autodesk Support
Autodesk Support
Beta builds of Autodesk Fusion 360 and Autodesk Sim 360 must be uninstalled prior to installing the R1 version. For instructions on how to uninstall previous beta builds, see below.
WINDOWS
Uninstalling
  1. Go to the Start Menu > Control Panel > Uninstall Programs.
  2. Select the existing Autodesk Fusion 360 and/or Autodesk Sim 360 entries from the list and start the uninstaller.
  3. Upon completion of the uninstall program exit Control Panel.
Clearing your cache files
  1. Launch Windows Explorer.
  2. Navigate to:  C:\Users\<username>\AppData\Local\Autodesk
  3. Delete the following folder:
    1. Web Services
  4. Next, navigate to:  C:\Users\<username>\AppData\Local\Temp\Autodesk
  5. Delete the following folders:
    1. Autodesk Fusion 360 and/or Autodesk Sim 360
    2. BrowserCache
    3. PLM360Cache
  6. Now navigate to C:\Users\<username>\AppData\Roaming\Autodesk
  7. Ensure the following folders have been deleted. If they haven’t, manually delete them.
    2. MC3
    3. Neutron Platform
    4. Neutron Platform 1.0 (if present)
    5. NINVFUS (if present)
    6. NFORGE (if present)
    7. g.      NSIM
MAC
            Uninstalling
  1. Move the Autodesk Fusion 360 and/or Autodesk Sim 360 dock icons to the trash.
  1. Start a new Finder window.
  2. In the Finder Menu (Apple bar on top), select Go > Go to Folder
  3. Enter ~/Library in the dialog that comes up
  4. Browse to Application Support/Autodesk/and move the following folders to the trash:
    1. Webdeploy
    2. Web Services
    3. Autodesk Fusion 360
    4. MC3
    5. Synergy
    6. NINVFUS (if present)
    7. Neutron Platform
    8. Common
    9. Autodesk Sim 360 (if present)
    10. NSIM (if present)
  5. Next navigate to $TMPDIR/Autodesk (open a Terminal window, and type: open $TMPDIR/Autodesk) and move the following folders to the trash:
    2. BrowserCache
    3. Neutron Test Application
    4. Project Forge (if present)
    5. Project Simulus (if present)
Can you test uninstalling per the above instructions and then re-installing R1?
Hope this helps!
Nathan Chandler
Principal Specialist
Message 4 of 28
schneik-adsk
Can you direct message me the emails used to create your autodesk id's for these accounts? It will allow us to find the log entries and identify what we need to do to fix the problem.  Thank you, and sorry for the problems.
Kevin Schneider
Message 5 of 28
[email protected]
Inviato da iPad
Message 6 of 28
I think there is a problem with my account. I installed Fusion on another computer (where I had Fusion) and I have the same problem!
I tried to create another account and it says it is not registered
Fabio
Message 7 of 28
Is there any news for my problem?
thanks
Fabio
Message 8 of 28
schneik-adsk
I am checking for you.
Kevin Schneider
Message 9 of 28
Everything went fine ... now it works;)
Fabio
Message 10 of 28
schneik-adsk
Great, We confirmed that there we a handful of accounts that got stuck (7) and yours was one. It was fixed over the weekend.
Kevin Schneider
Message 11 of 28
i've tried my accounts and it doesn't work.
Message:
Your Autodesk ID XXX is not registered with any hubs on Autodesk 360.
I'was using Fusion 360 very well when it was Beta version. Why is this cause happening?
Message 12 of 28
philip.s
Hello Abdullah,
Were you able to proceed with the full beta uninstall (directions linked here) prior to installing to new Fusion 360 release?
If not, can you please do so and let us know if that resolves the issue?
Message 13 of 28
florian.b
i have the same problem. getting "Hub configuration has failed"  " You are signed in with Autodesk-ID ... Not you?"
I already deinstalled it step by step but that had no effect.
Message 14 of 28
philip.s
Welcome to the community Florian!
This same issue was discussed in another forum thread, where the workaround was identified as disabling ones antivirus.
Can you please give that a shot and let us know if it works for you as well?
Message 15 of 28
working on a Mac so no AntiVirus.
I created a new Account. Now it works. Not the nice way but it worked for me.
Message 16 of 28
philip.s
Apologies for the inconvenience and thanks for confirming.
Would you mind sending me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your previous account info so that we can investigate accordingly?
Message 17 of 28
Same issue here. Created new account - still does not work.
Message 18 of 28
No antivirus, even FW turned off, btw.
Message 19 of 28
innovatenate
Autodesk Support
Autodesk Support
Can you try logging into https://360.autodesk.com/ with the username adn password first and then opening/logging in to  Fusion 360?
Are there any special characters in the username?
Nathan Chandler
Message 20 of 28
I have encoutered the Hub Configuration has failed condition.  I have attempted using both a Windows 7 PC and Mac 10.8.5.  I have tried creating another user account and been informed there is no hub for that account.  Earlier versionshave not been installed on either system but I did go through the unistall process described and reinstalled on the PC with no change.  I also disabled my anto virus an that did not resolve the issue.
I would like to give the software a try, but things are not going well.  Your assistance would be appreciated.
