Install with limited internet connection
Installing fusion is a real problem now.
Is it possible to install Fusion 360 in a different way?
baribak
There are a few ways to install Fusion on your system however can you elaborate on what your current connection issues are? Is it you only have connectivity during certain times of the day or is the connection itself extremely slow?
Also, if you try installing now is there an error or issue you are seeing?
Thanks!
Regarsd,
Kevin Baribault
Fusion 360 Quality Assurance
What are the different possibilities?
See my other entries for specific problems.
innovatenate
Autodesk Support
Autodesk Support
It sounds like you have a proxy server at your work environment and you do not in other environments. Is this what is meant by "limited connection" or is speed a concern?
The suggestion in the below link may be helpful.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Nathan Chandler
Principal Specialist
