Inside sketch: How do I convert multiple connected splines into a single one?
janus2
janus2
Hello!
I have the following problem: After I have drawn a closed contour from a photo. It consists of splines. After some edits  it is not drawn as a contour in one step. It is a combination of several splines connected at the ends.
The contour is closed. Extruding is no problem. But if, for example, I want to insert a fillet later, I have to select each spline element separately.
Is there a way to connect the individual elements so that they behave like one?
Thanks a lot for your help
Jan
g-andresen
you can't connect the splines.
But if you want to round the body you can also mark all edges and round them together.
regards
günther
janus2
Thanks for the quick answer.
If there is no possibility, then I don't have to search any longer.
The fillet was just an example. So the question was more in general.
