Inside Corner Fillet/Pipe
rhetteshleman
rhetteshleman
I'm trying to create a fillet on the inside corner of this model where the blue line is on screenshot. I've also tried Pipe but not much luck. Open to suggestions. Thank you
rhetteshleman
I figured out one way, made a triangle face where the fillet needed to start then used sweep along path. I'm sure there's a better way.
g-andresen
There is no overlap between the body elements.
(view in My Videos)
günther
TrippyLighting
How are you going to manufacture those infinitely thin edges?
Infinitely thin edges cannot be filleted for obvious reasons.
