Inside Contact / Joint not working properly
ju.ha.sch
ju.ha.sch
Hi guys.
Wenn I move the slider (with the pin on top), the pin jumps out of the slot (1) => (2). Once outside it interacts with the outside of the body (with the slot) (3). It seems to me it does not 'see' the inside shape of the body (with the slot).
Any ideas how to fix this?
Thanks for any help
joel.palioca
Would you be willing to share your file?  You can add it here or email it to me directly.  This way I can take a look at the setup that you have.  In theory depending on how your joints are setup or how your leveraging contact sets, the slider's slot should stay on the pin.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Autodesk, Inc.
