Inserting SVG
Inserting SVG
Nickduino
Inserting SVG
Nickduino
I'm trying to design a (very simple) stamp. I'd like to know what's the best way to extrude the svg logo as my attempt failed.
I'd like the blue parts to be extruded, not the white/transparent ones:
I'd like to know how to dimension the logo as well (set its height, for instance) but it's not as important as the first question.
davebYYPCU
Your file is ready to extrude, start Extrude command, click in the three blue areas to select the regions to extrude, set how high, then Ok.
The SVG file is fixed when imported, edit sketch 2, select all the articles in that sketch and click on the padlock item in the constraints panel.  All selected articles will turn blue, then you can scale or dimension for size
Pic has all selected but not clicked on the Fix Button yet
davebYYPCU
Just a note,
your sketch 1, does not match the platform body, and the yellow icon needs to be fixed, (in sketch 1, is not a rectangle any more.)
Might help....
WHolzwarth
The internal parts of the big A's were missing in the SVG. New one attached.
Walter Holzwarth
Nickduino
Thanks!
I couldn't work out how the scaling tool has to be used but I did it when importing, so all is well.
Nicely spotted!
