Is it true that you cannot Insert Derive into a sub-component of a design?
I have a design that consists of several Components. I activate one of those Components and then select to do an Insert Derive. I select the desired Component that I want to Insert Derive BUT it gets inserted as a Component below the main Component of the design, NOT into the one that's activate. Do ALL Insert Derived Components get put as sub-components of the main design's component?
I had already discovered that you can't re-arrange Insert Derived components after they've been inserted, trying to "manually" move it into some other sub-Component. You get an advisory message saying that such re-arrangement of Insert Derived Components is not currently accommodated. But is it true that you can't even INITIALLY have them Insert Derived directly into some sub-Component?
