Insert a cylinder into an object to create an indentation
Message 1 of 13
I tried finding tutorials but nothing super similar to my project was found.
Someone has asked me to create straw toppers; so I need a 5/16" cylinder indentation made into the bottom of the topper object.  I've got the topper sized and the cylinder is created and positioned.  I just don't know how to use the cylinder to create an indentation into the topper.
Replies (12)
Message 2 of 13
wmhazzard
I don't know what a straw topper is but if you have a cylinder then use combine / cut to remove the cylinder shape from the top.
Message 3 of 13
chrisplyler
Message 4 of 13
TheCADWhisperer
File >Export and then Attach your *.f3d file here.
Message 5 of 13
Attached is what I currently have so far.
Message 6 of 13
laughingcreek
The mesh file your starting with has a hole(s) in it so it's a surface body instead of a solid.  I would do this entire project in mesh mixer or some other mesh editing software.  fusion is not a good program for editing this type of model.  Mesh models and nurb/brep models (like what fusion makes) are completely different animals.
Message 7 of 13
TheCADWhisperer
What software did you use to create the helmet?
Message 8 of 13
chrisplyler
The SURFACE body that exists doesn't seem to have any holes in it. It just needs to be stitched together so it turns into a SOLID body. Then you can make the recessed hole in the bottom.
But it is a terrible model.
Message 9 of 13
chrisplyler
This video I've made for you is longer than it needs to be, because I wasted the second half of it just moving the helmet closer to the origin so I could create a section view.
https://knowledge.autodesk.com/community/screencast/a2917251-b363-40c2-a658-965d8bf53248
Message 10 of 13
Thank you for the recommendation.  I use Meshmixer for my 3d prints; so I should be able to try there.
Message 11 of 13
I found the model on Thingiverse.  All I did was rescale it down to the size I need.
Message 12 of 13
Thank you!  That was very easy to follow.
Message 13 of 13
chrisplyler
Glad to help.
But honestly working with triangulated mesh files in Fusion, while possible, is not recommended if you have Meshmixer or other software that is designed for the task.
