Good day all - I have seen several postings regarding Inlays, however nothing that addresses the multiple designs I am working with. Specifically I was following a post on a guitar fret-board, however the inlays are straight and flat, which is not efficient for shapes and text. Below is a link to a similar process from Broinwood, who uses a "v carve" method, which leaves a tapered and smaller edge towards the top, and a larger base that is cut off and fills in the void/pocket cut out - which is also done with a v-bit.
While I have attached these F3D files, I am trying to avoid using VCarve or Vectric software for this process. I am a huge Fusion 360 fan, however this process is not intuitive at all nor can I find any tutorials to figure out how to best create to files, one with a male and one with a female component, which will fit together and leave zero gaps.
I have tried multiple cutting methods, from trace, to Engrave. Engrave seems to work somewhat, but requires a guessing method to ensure the parts align. Perhaps there is a way to "fit" the components together through the assembly option in Fusion? Willing to try any method or provide different files. Just looking for a way to make this work as I have a ton of different inlays I want to accomplish, and need a quick and efficient way post drawing to make this happen.
Link to Broinwood Samurai Star Inlay
