Individual Timelines For Each Part
davecc
davecc
To simplify making modifications to individual components while working with large assemblies it would be of great help to be able to view the timeline individually for whatever  part is selected instead of a timeline for all of the parts at once.  The timeline would change every time an individual part was selected.  Once the part had been modified to the users liking the timeline would revert back to an assembly timeline for all of the components within that assembly. With only showing the timeline for individual parts it will simplify the process of finding and modifying individual components in a huge timeline.
schneik-adsk
If you click the radio button  at the end of the component's name in the browser you will activate it.
You can also right mouse click and activate a selected component.
Activating a component will only show that component's timeline features much like you are asking.
Kevin Schneider
schneik-adsk
Kevin Schneider
davecc
Thanks for the tip on handling modification to individual parts. It's
exactly what I was looking for. I checked it out and it's perfect.
Don't change a thing. Thanks again. Dave
schneik-adsk
Great, glad it worked for you!
Kevin Schneider
The problem with this solution is it only seems to show the features added after the body was converted to a component. so all the original features that were used to create the geometry don't show up. making it fairly useless
Also, there is no obvious was to subsiquently de-activate the component
