In Sketch, copy paste lines and text copies lines only
chrisYBGLU
chrisYBGLU
When in a sketch, selecting a rectangle, some lines and some text, ctrlC copy, ctrlV paste, pastes the lines and the rectangle, but only an unusable outline of the text.  double clicking the outline does nothing.  Should copy both.
Copying text alone works.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @chrisYBGLU,
I experience the same behavior as well when trying this. I'm curious as to why that is - I expect it would work the same way as well, but there may be a reason behind it. I'll dig deeper into this. I did want to note, if I select the text and then Explode it (which now makes the text unable to be edited), and then window select and copy it, it will paste accordingly. I'll go ahead and log this with development anyways.
EDIT: Pretty certain it's a bug the more and more I dig into it. I've reported it as FUS-34848
Thanks for reporting this,
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
