Impossible Dovetail Puzzle in Fusion
Ezekiel12
Ezekiel12
I tried to create Impossible Dovetail Puzzle in Fusion, which wasn't really hard. But I actually had tough time with that stand. I wanted it to fit perfectly. What do you think? Would you took another approach at this or same and why?
http://a360.co/2iP4Q1E
Have a nice day,
Matt 🙂
jeff_strater
Hi @Ezekiel12,
I would use Combine for the stand.  Instead of the second loft that you have in your timeline for the stand, I would stop after the first loft, and subtract the bottom body from the stand.
You may want to add some tolerance to allow for manufacturing tolerance, for that you would use Press/Pull.  I can show you how to do that, if you need it.
Here is a screencast showing how to use Combine:
Jeff
Jeff Strater
Engineering Director
Ezekiel12
Hi @jeff_strater that's actually a lot easier then I did... thx 🙂
