Importing .SAB file
Importing .SAB file
matej.biro
Importing .SAB file
matej.biro
Hello, i have a problem to open .SAB files sent from customer. If i try create fusion design , it start converting but at the end write failed. I tried it through web page and it says : "Oops! Sorry. Referenced files are missing. Please upload model *****.SAB including all references." and when I check details: The version of the file:model *****.SAB is not suported.
I dont know what versions are those files. I read at forum that sab files are supported by fusion.
Can you help with that? Thank you.
ZhengJunxiang
Hello, Fusion supports SAB v7.
ZhengJunxiang
By the way, I can help to check your SAB translation problem further, if you are free to provide the file. 🙂
matej.biro
Sorry but i cant share those files. How can i check the version of those files? I am searching in properties but cant find it?
ZhengJunxiang
Understood the restriction.
Alternatively, if you have a Binary File Viewer in you hand, could you please open your SAB file in the tool, and copy a few lines top of the file? I might be able to tell you the version then. It might work. 🙂
An example is as follows. In this example, this file version is 7.
matej.biro
I dont have it, I will try to get them as STEP, thank you anyway.
