Importing Illustrator Text Issue
daschenbrener_0069
daschenbrener_0069
Hey guys, a newbie question but i haven't been able to successfully import it .
What is happening is the centers of the "A" , "b" and "e" are not being removed.
I've outlined the text and export using dfx and svg and no success
Thanks in advance for some assistance
jeff_strater
you'll have to share the design for more detailed help, but likely there is a "leak" in the middle section of those letters.  Use the "divide and conquer" method for finding the leaks:  find-leak-in-sketch-geometry .
Jeff Strater
Engineering Director
g-andresen
What behaviour do you expect from the inner areas? Should they be white?
This is only the case if both the outer and inner contour have gaps.
günther
