Importing CSV Data Fusion 360
I tried to import some points.attached excel data saved as CSV with X,Y,Z coordinates.I've already used Add-in " ImportPointsCSV " and it doesn't work.I tried to use both of  " ImportSplineCSV " scripts.It works but with false coordinates ( for example : my coordinates : 500,0,0 mm   ....... shown coordinates : 5000,0,0 mm ) and besides I don't need the splines.
daniel_lyall
your posting in the wrong spot this is a API and scripts question, I have asked for it to be moved more chances of an answer
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
vladimir_michl
You can try the globalized ImportPointsCSV and ImportSplinesCSV scripts from www.cadforum.cz - see:
http://www.cadforum.cz/cadforum_en/how-to-create-a-profile-from-imported-xyz-points-in-fusion-360-ti...
Vladimir Michl, www.cadstudio.cz
