Imported Canvas Visibility Issues
sewellad1
Observer Observer
sewellad1
Observer
Observer
Hi. I am trying to make a model of something from an imported image. When I import images the image is barely visible. I can set the opacity to 100% and it is still barely visible. Sometimes when I do certain commands the image will go fully opaque, but when the command is complete it goes back to barely visible. The photo below shows the darkest anything I import gets. I feel like I am missing some setting or something, but I am a novice at fusion and can't find any information on canvas visibility issues like this. Any help is appreciated. Thank you.
jhackney1972
Please attach your model as well as a copy of your image you are trying to use as a Canvas.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
jeff_strater
What are those "certain commands"?  Can you tell us when that happens?
Do you have multiple components in your design?  Is a component other than the one that contains the canvas active?  This looks like the dimming that occurs by default when one component is active.  Try changing this preference:
Jeff Strater
Engineering Director
sewellad1
Observer
Observer
Thank you for the replies. Jeff, your information about active components solved my problem. Even knowing that it makes sense to have the canvas in the component that I am working on, I didn't notice that it wasn't in the component tree that I was working on.  Thank you very much. Sorry for the lack of information as well. This is my first post so my novice is showing.
