Imported bodies to "assemblies"
SEIZMICdesign
SEIZMICdesign
So I have an imported model consisting of a few dozen parts/bodies. I'm wondering what the best practice is for converting these bodies into "assemblies" (I come from the SolidWorks way of thinking). Ultimately, I need to group several components into an "assembly" and there will be a number of assemblies, each of which hinge on each other. I've converted the bodies into components, but now I'm faced with a number of options. I could:
A) create rigid group assemblies
B) create a selection set
C) create a new component
Once I create the proper group/s I will need to create joints between them as I mentioned before.
What is the recommended process for this type of model?
TrippyLighting
If you can share the model that'll get you help most quickly.
TrippyLighting
This screencast may provide some help.
SEIZMICdesign
This helps a lot actually, thank you.
