Import SVG's to dimensions rather than some scale factor?
benjamin786UD
benjamin786UD
So I'm importing a graphic which is a company logo and I would like to be able to set its initial size via a dimension rather than a scale factor so that I know its width and can more easily align it centrally? Is there no way to do this? The svg insert tool seems too basic?
g-andresen
Scalefactor = desired length / existing length
günther
TheCADWhisperer
Scaling is done with dimensions.
Attach your file here if you can’t figure it out and indicate the desired size.
Once someone shows you how - you will know for all future endeavors.
jeff_strater
you can also use the "scale entire sketch on first dimension" preference:
here is a screencast:
Jeff Strater
Engineering Director
benjamin786UD
This is the sort of thing I think I was looking for, thanks!
