Import problem (ARTCAM)
When i importing a model from FUSION 360 (STL) in ARTCAM appear jagged edges?
How to prevent this problem?
innovatenate
Autodesk Support
Autodesk Support
Have you tried using a different file format? Like an IGES file?
https://www.youtube.com/watch?v=FHiA49hYGSo
See how to export design in Fusion in the below link.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Another possibility may be to use the CAM environment native in Fusion 360.
I hope that help! Let me know if you have any questions.
Nathan Chandler
Principal Specialist
dillon.moulder
Hi @Anonymous,
You might be interested to know that with the Autodesk ArtCAM 2018.1 Update, you can now export a quadrangle mesh in OBJ format from Autodesk ArtCAM Standard 2018 or Autodesk ArtCAM Premium 2018. For further information on the Autodesk ArtCAM 2018.1 Update, click here.
Kind regards,
