Imbedded Part Structural Constraint
brodierobins
brodierobins
Community Visitor
Community Visitor
I am working on a project that has a plastic part imbedded into a polystyrene part in the manufacturing process.. similar to a Insulated Concrete Form (ICF). Is there any way to create a structural constraint between the imbedded part and the polystyrene part? I am wanting to analyze the pull-out strength of the imbedded part.
kacper.suchomski
Hi
I can't see the project, so I can't tell if the polystyrene part has an empty space for mounting the embedded part.
If not - you need to make a combination of bodies (components) in cut mode.
If you've already done that, it seems that setting the contacts between components in the simulation environment should do the trick.
Kacper Suchomski
