My part is 2mm x 89mm, it is basically a template in order to print a decal on an inkjet printer. I am trying to go from the modeling environment to the rendering environment but, I am getting messed up because of the zooming size. If the part is 2mm x 89mm in the modeling environment then I need the rendering environment to reflect this so it is a true representation of the modeled part size. I am pretty sure it has something to do with the Zoom ratio on my display however when I zoom the display down small enough so it approximately represents the true part size I lose the text detail all together. Rendering picks up all the other components but not the text.
