im making a headlight intake and i need help matching the slope on the lense.
kkmecham88
kkmecham88
Community Visitor
Community Visitor
im making a headlight intake for my car. i cant figure out how to make the tube that runs through the headlight to match the lense of the headlight as well as i need to add a lip to seal the tube on the headlight.
evanp4509U4JZ
I believe this will best be done in the FORMS environment. I would first create a plane close to the average surface of the lense, then in forms, create a T-spline plane, or flat, on that plane. This T-spline plane can then be manipulated to match the curvature of the scan of the headlight. That T-spline can then be used to split the cylindrical body you have to give it the profile of the lense.
