Illustrator files
Illustrator files
Illustrator files
I continue to have problems to import the tracks illustrator saved in SVG format.
I am sorry because I often find myself having to draw elements from the Adobe software.
Do you have any solution or project future compatibility with files from illustrator?
thanks!
Fabio
jakefowler
Hi Fabio,
Thanks for posting about this. We've actually tried to make some improvements to the SVG import quality in the upcoming Fusion 360 update, which should be with you sometime tomorrow. Would it be possible to try importing the problematic SVG files again after the update? If you are still getting unexpected results after the update, let us know and we may need to do some investigation with the particular SVG file(s).
Thanks!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
OK... 😉
Fabio
Fantastic guys.
With the update everything went fine.
The same file swg reads smoothly
thanks!
Fabio
jakefowler
Hi Fabio,
Great to hear 🙂 Let us know if you hit any other issues.
Thanks!
Jake
Jake Fowler
Fusion 360
