I don't see any mention of how Fusion treats even/odd values in IF statements, here. Am I looking in the wrong place?
I need a parameter for a feature pattern that offsets the seed to a different location depending on if it has an even or odd number of instances along a particular axis.
I am aware that there are alternative (possibly better!) means to the same end, but this question is about even and odd values in IF statements. I just want to know if there is an intended workflow or workaround to use it in logic in Fusion.
Are there more operators than what is shown in the link above?
Link copied
