iam trying to make cnc chain
iam trying to make cnc chain need help on how to cam the  inside of the oval parts any help would be apprated i have video and out lined the oval in yellow so u will see what iam talking about
I'm not quite sure what you need help with, can upload the video of your problem?
iam trying to cam this dxf file i was told to use smaller bit size i have done that i.ll attach the file for the dxf cable carrier I'am still trying
Is this how you want this to work? Otherwise you might want to attach your own Video.
THAT SHOULD WORK IS IT 3.175MM THICK
The End Mill (= the second) is 1mm in Diameter
