I've run into something
Hi guys.
I'm very new to Fusion 360.
I've been using a project as a learning tool and have run into something I can't figure out.
I've attached a screenshot of my problem.
I may be wrong but looks like I've set a construction point that has somehow become extruded.
I can't get rid of it.
If anyone can offer some advice I'd appreciate it.
Fueler
If you are referring to the line sticking up out of the hole, there must be a sketch of it in the timeline somewhere.
Anything light up when you click on the line?
Would it be next to the yellow Push/pull icon in the timeline?
construction lines are dashes
Thanks for the reply.
Yes I can find it in the timeline and I can find the point in the original sketch but I can't find a way of deleting it.
See attached screenshot (look in the horrible "circle" bottom left).
Feature is on perimeter of 14mm hole; looks like a "point" marker and 360 reports it as a sketch point.
I don't understand how I managed to extrude it.
When I select it the following warnings are present.
