I cant split a circle!
hughesmatthew1986
Message 1 of 12
hughesmatthew1986
ok
i know this has been asked in various different ways in the past but my brain is not working on a friday,
in the attached file im trying to create 12 equal segments with a gap of .5m mill, if i can achieve this then i can extrude it and such to make my final design.
but for love or money i just cant get my head around it and would be greatful if some one can explain to the idiot behind this keyboard on how to do it.
Cheers Matt
Replies (11)
Message 2 of 12
wmhazzard
Is this what you are looking for?
Message 3 of 12
hughesmatthew1986
No sadly not. I was looking at segmenting the inner circle with a little gap between each.
Message 4 of 12
hughesmatthew1986
Sorry I should of been clearer
Message 5 of 12
laughingcreek
you still haven't been very clear.  maybe a hand drawn sketch?
Message 6 of 12
hughesmatthew1986
 so I’m trying to replicate this but in sketch form currently.
does that help?
it would be 12 segments on the inner circle due to the outer circle been the far outside section.
Message 7 of 12
TheCADWhisperer
Why is your Sketch1 not at the Origin?
Blue lines (or circles) should keep you awake at night.
Isn't that a simple Revolve, Shell, Extrude, Circular Pattern?
Message 8 of 12
hughesmatthew1986
What is a origin? And it might be what you said. But as I said I have been tinkering around and have no clue of such things.
Message 9 of 12
TheCADWhisperer
@hughesmatthew1986 wrote:
What is a origin?
BORN Technique
Message 10 of 12
hughesmatthew1986
Right the little dot at the middle.
As I been playing/learning I just click the screen. Didn’t think that would make a difference. But I will keep it in mind for future. Thank you.
Using your previous screenshot I will do some more tinkering/playing/learning and see if I can figure it out.
I got extruding down that’s the easy bit for me but I will persevere.
Message 11 of 12
TheCADWhisperer
I attached the file too.
Simply reverse and step through the Timeline to see what I did.
Message 12 of 12
hughesmatthew1986
Thank you,
hadnt seen that as i was on my phone
will have a gander now. thank you once again
