I cannot edit gridlines. please help
eriorellana89
Message 1 of 13
eriorellana89
when i click the button it highlights blue but nothing pulls up.
Replies (12)
Message 2 of 13
jhackney1972
It is hard to tell what icon you say is blue but I think you are on the wrong one.  The Screencast will show the process.
John Hackney, Retired
Message 3 of 13
eriorellana89
correct that is exactly what im trying to access but when i hover over the button and click it nothing happens.  I click on the grid line, i click on the little arrow next to it but nothing.
Message 4 of 13
g-andresen
please show your actions in a screencast for better understanding
günther
Message 5 of 13
eriorellana89
just like in the video above except nothing happens when i click on the grid box.
Message 6 of 13
jhackney1972
What you supplied is a screen capture, not a Screencast as requested.  What we are looking for is the "state" of Fusion 360 when you select the icon.  However it sounds to me it is time to do a "clean" uninstall and reinstall.  Make sure you restart your system between the uninstall and reinstall and also that you are using a computer profile that has sufficient rights.
Message 7 of 13
mango.freund
@eriorellana89 hello - unfortunately you want to use something like grids. a lot feel bothered and annoyed by the grids and switch off this mischief. helpful in tinkercad - very annoying in fusion. greetings mango
Message 8 of 13
eriorellana89
does the paid version of fusion 360 perform better??
Message 9 of 13
eriorellana89
im not sure what you are referring to?  My issue isnt that i dont want to use grid lines,  my issue is that i cannot edit my grid lines or even get the option to
Message 10 of 13
jhackney1972
You never supplied a Screencast but you did say that you clicked on the "Down Arrow" beside the indicated icon and it gave you nothing.  This would indicate to me that the Fusion 360 installation is not complete and you need to do a Clean Uninstall and re-install of the application as I mentioned before.  Did you do this?
Message 11 of 13
g-andresen
If you can't access the grid settings like in the GIF you should follow @jhackney1972  and do a CLEAN UNINSTALL.
günther
Message 12 of 13
mango.freund
Message 13 of 13
TheCADWhisperer
