I can't give arc size in technical drawing
nferhatoglu
Message 1 of 8
nferhatoglu
I can't give a spring measure to the edge of the elbow I showed in the picture.
Is there any way or solution to this?
Replies (7)
Message 2 of 8
HughesTooling
Can you share the f3d file please? One thing to check is is it really an arc and not a spline? Can you add a radius dimension?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
TheCADWhisperer
@nferhatoglu
The STEP file that you Attached here is not the same geometry illustrated in your 2D drawing?
Message 4 of 8
nferhatoglu
It doesn't matter, both are the same.
I can give other measurements, but not the spring size. I edited the message.
Message 5 of 8
HughesTooling
I guess this fails because that is a tangent edge.
I found a workaround using a section view. You can place the source view off the sheet by the way. I would like to tag someone in from AutoDesk but it seems like the elves are busy breaking the forum again!
Mark
Mark Hughes
Message 6 of 8
nferhatoglu
Thanks Mark, that's a nice solution.
However, when I tried this arc measure in other programs, I was able to give it all, including FreeCAD.
I think authorized friends will solve this simple issue, we are waiting.
Message 7 of 8
HughesTooling
@ClintBrown3D Is this a known problem?
Thanks Mark
Mark Hughes
Message 8 of 8
harry.doldersum
It's another workaround, but by copying the component to a sketch & activating the sketch in the 2D drawing, you *could* dimension the elbows as required.  Switch the body off, to place the elbow dimensions - switch it back on when done.
Please see attached.
