I can't choose the sketch point for line of reference
Hi guys;
ı added construction line to create sketch point at the end of rectangle. When ı create sketch on XZ plane, ı can't choose sketch point at the end of the rectangle. Always, choosing the grids line. What do you think  ı do ?
Note: You can see better on my upload pictures.
Thank you from now for your helps.
1122
chrisplyler
You are talking about two different sketches. One on XY, and one on XZ.
The construction line and its end points exist in the first sketch. The do not exist in the second sketch. Therefor you cannot select them when you are working on the second sketch.
If you want to use something from the first sketch while you are working on the second sketch, you need to use the Project tool, to capture the item from the first sketch and create a representation of it in the second sketch.
Watch how I use the Project tool while I'm working on my second sketch, to capture the end points of the construction line from my first sketch, and create purple points in my second sketch. Now those purple points in my second sketch will always stay with the end points of that construction line in my first sketch. So in the second sketch I can attach other things to those purple points, and therefor create a dependency. Items in the second sketch will move according to changes in the first sketch.
Video: https://knowledge.autodesk.com/community/screencast/466f6ac9-ccb3-41a2-8cf8-f322af1a7040
chrisplyler
Also, you can change the grid settings here, including whether Snap is turned on or off.
That is not problem. Problem is, without doing anything extra, ı can't choose sketch point. For example, these videos;
https://www.youtube.com/watch?v=pqXCswoa3F4&list=PLrZ2zKOtC_-DR2ZkMaK3YthYLErPxCnT-&index=7&t=928s (15:35 min)
and
https://www.youtube.com/watch?v=Xho87HJ-XDo&list=PLrZ2zKOtC_-DR2ZkMaK3YthYLErPxCnT-&index=9&t=143s (2:19 min)
He without doing anything extra, just choosing a sketch point for drawing line. He is not projecting on video. Why ı can't do this?
I hope, ı was able to explain my problem to you.
laughingcreek
He has this setting selected in preferences-
most of us turn this setting off early on because it can cause unintended reference projecting if not careful.
Thank you so much. Problem is solved!
ashtone6
Community Visitor
Community Visitor
Thank you!!! This was so helpful!
