Being new to this it may be a simple question but I can't seem to figure out what to do next to make an "I-Beam".
First attempt: I made a rectangle and sized it. Then made another rectangle the size of the lower portion of an I-Beam and used "cut" to remove the material. That did remove the lower material forming 1/2 of a beam.
I could have made a second removal rectangle for the top I beam cut out, but figured if I made a rectangle of the correct size external to the Beam I could copy it and move it twice to the upper and lower cut areas of the proposed I-Beam. I was successful in this but could not get it cut.
Guess I must be thinking of this wrong, but I am at a loss. It should not be that difficult to make a simple I-Beam.
