I am looking for some resources that might teach how to do realistic spring simulations
sethineer
sethineer
I am almost starting to suspect there is no way to do realistic spring simulations in fusion 360 based on tutorials I find on youtube.. For example, one guy there does it by creating revolute joints at discreet intervals along the spring, and then slider joints to constrain the compression linearly.
But I don't see how this method could possibly model a real spring, through, if you are choosing revolute joints at DISCRETE positions on the spring, when the force applied to a REAL spring causes a reaction force that is CONTINUOUS. For example if you were to run a simulation on this, all the pressure on the metall would be relieved  at your joints, which don't exist in springs, instead of along every continuous point of the spring like a real spring. So if you were trying to find out how to model a real spring to determine what spring constant you need to counter a given force, I don't see how this method helps. Is there any way to model and simulate a real spring in Fusion 360?
Say, for example, if I want to simulate a door closer to determine what torsional spring constant required that is  just enough counterforce to close a door of a given weight.
Are there lessons anywhere that might cover ways of doing realistic simulations involving springs in Fusion 360?
sethineer
Yes, I know you can just use F =-kx or τ = -kxr to mathematically find your spring constant in the example I give. But that was just an example. For the most part,  I want to simulate the behavior of REAL springs in more complex systems.. Depending on where I situate my springs.. I want to be able to model the true behavior of the system.
MichaelT_123
Hi Mr SetThineer,
Yep, using YT solutions uncritically (or F360 ones) is like relying on a virtual toilet during a deep sleep dream.
Satisfaction does last until waking up ... only.
There is extensive knowledge/science about the mechanical behaviour of diverse types of springs.
The equation you presented relates to a very simplified 'primary school' curriculum spring concept.  The body of knowledge these days is readily available ... so perhaps it would be worth studying it a little bit.
Generally, it is possible to model relatively reliable some spring models in F360. It requires some number crunching (along with additional model specifications).
Consider looking at:
Solved: Auger flight sections into flat pattern? - Autodesk Community - Fusion 360
Variable Pitch Thread/Helix - Autodesk Community - Fusion 360
Regards
MichaelT
MichaelT
TheCADWhisperer
You would need something like Autodesk Inventor Professional - Dynamic Simulation to analyze Spring Forces.
Here is link to an example - sorry about the low resolution of the video...
https://www.youtube.com/watch?v=gdVtWpftX8o&list=PLp5izJt_zvN08mpY4UcYrzJV2N6QOLAIR&index=31
