Hypoid gears
Hypoid gears
tabusca_andi
Observer Observer
Hypoid gears
tabusca_andi
Observer
Observer
I'm trying to design a pair of hypoid gears and I was wondering if there is any kind of tool or add-in in fusion to do that. It could also be very helpful if someone could refer me to somewhere where somebody explains the math behind hypoid gears so that I can make them myself.
johnsonshiue
Hi! Here are a few related discussions.
https://www.youtube.com/watch?v=AorTmpMj0yY
https://www.reddit.com/r/Fusion360/comments/rnm110/hypoid_gear_tutorial/?rdt=61989
The most difficult portion of the design is to figure out the path. Once the path is determined, you may use Solid Sweep to sweep the cutting tool along the path to create the precise geometry.
Many thanks!
Software Test Engineer
