10:08 AM
I am trying to use the hydrostatic pressure function to simulate water in a simple 1m square container with 6mm wall thickness and an open top.
I modelled the container, moved to simulation and did the following.
- Set the study material to polyethylene, low density
- Set the bottom external face of the container as a fixed structural constraint
- Added structural load, changed type to hydro static which enabled gravity.
- I selected the four internal faces of the container.
- I selected point coordinate and set y to 500mm i.e. half the height of the container.
- I left fluid as water and hit okay.
I then solved the model and the results don't make sense to me for example the max displacement is at the open end despite me setting the water level to only 50% of the container. Also some walls deform out which I would expect but some deform in and the corners of the container aren't deforming. I would have expected to see the walls bulge low down on the container but maybe I'm mistaken.
Anyone know what I've done wrong here?
Thanks in advance
