How would you go about adding this feature to this part?
I've gone and added a screw hole info this curved surface by placing a circle sketch on the flat underside and pushed the cut up and through to the curved side.  Worked very well thank you very much!  🙂
My problem now though is how to add a second circular cut to the top of the curved area for the screw head. (Screw heads are wider).  So just a little wider than the existing cut and only a few mm deep from the top down.
I've wracked my brain on this one but am stumped.  Does anyone have a suggestion?
(images attached to show existing model and proposed cut)
Thanks a tonne... Rob
Pavel_Holecek
Hello Robert,
There is no possible to select/use hole feature on curved surface. You can create a new sketch on offset work plane then project existing hole and create new circular profile for cut extrude.
See my attchached video.
Regards
Pavel Holecek
Autodesk QA team
Thanks Pavel, I really appreciate that.  It did the trick.  I've attached the (not finished) feature.  It needs improvement but now I know how.
Again, thanks so much!  Rob
