Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How tp project entities at an angle or along an axis?
2 REPLIES 2
akschu
100 Views, 2 Replies
Suppose I made some arbitrary shape then create a sketch above it on a plane that is 45 degrees tilted.
How would I project that shape straight up along the construction lines so that the entity on the angled sketch looked like it would if I extruded the shape through the angled plane the split it, then created a sketch on the new face:
I suppose I could extrude, project, break, then remove the bodies I don't want, but that seems like an ugly way to do it.
2 REPLIES 2
jhackney1972
in reply to: akschu
Another way to do it would be use a Surface Body Intersect.  Model is attached.
John Hackney, Retired
etfrench
in reply to: akschu
Extrude/To Object or Replace face should work to create a body.  If you just want the sketch, then just project the geometry to a sketch on the angled plane.
ETFrench
