How to wrap a pipe around a solid?
autodeskN884Q
Message 1 of 16
autodeskN884Q
I have a bowl like so
No I want to create a path with the fit point spline tool, pipe the path and then wrap the pipe around the bowl.
Something like this
An export of my work is attached. Thank you
Replies (15)
Message 2 of 16
davebYYPCU
Checking the file - question.
The spline is very free hand and 4.25 times the circumference at the equator.
All of the spline or just x number of laps? 1 and 3 pictured
1 lap example
Message 3 of 16
sutherland-
Hi @autodeskN884Q
I would suggest looking into this tutorial, it will help you greatly in understanding how wrapping works and what is the best way to wrap a sketch.
Hope it helps.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 4 of 16
autodeskN884Q
Hey. Thanks for your reply.
I didn't know how to measure the circumference properly so I just did a random spline to explain my situation. I want to do only one lap (picture 1). But I'm curios to understand both methods if you dont mind
Message 5 of 16
davebYYPCU
Same method, just delete the circular pattern. for a single loop.
Might help....
Message 6 of 16
davebYYPCU
Emboss is limited to cones and cylinders, this dish is not one of either.
Message 7 of 16
sutherland-
The tutorial shows not only the possibility of Emboss feature, but also "Project to surface".
That feature can be applied in this situation.
Best regards,
Level  sutherland-
Member
Message 8 of 16
sutherland-
Please see attached file. This would be my take on the situation @davebYYPCU.
Neither is the "correct way". There are multiple ways of overcoming the wrap feature. 🙂
Best regards,
Level  sutherland-
Member
Message 9 of 16
TrippyLighting
@sutherland- wrote:
Neither is the "correct way". 🙂
May you enlighten us then what the "correct way" is?
Message 10 of 16
autodeskN884Q
Mhm yeah thats a nice approach. That's not exactly what I was looking for. I wanted to actually wrap my path around the bowl. But I guess you answered the question already in another reply: it's not possible.
So unless you say there is a way to actually do this I'll accept this as answer. Thanks for your time
Message 11 of 16
sutherland-
If you could be patient enough, then you could read the full reply. There are many ways of getting the wanted effect.
Thanks.
Best regards,
Level  sutherland-
Member
Message 12 of 16
TrippyLighting
As it comes to Fusion 360 I know all of the ways to achieve the desired effect 😉
I would like for you to demonstrate "the correct" way and then explain why it is more correct than others.
If you have the patience to do so ...
Message 13 of 16
sutherland-
My point was that there is NO CORRECT WAY of achieving the results. Everyone uses the features that they are used to in order to get the effect.
I will stop replying to your comments here, we are flooding the post with unnecessary replies. If you are interested, we can continue the discussion outside this post.
Cheers.
Best regards,
Level  sutherland-
Member
Message 14 of 16
TrippyLighting
@sutherland- wrote:
..., we are flooding the post with unnecessary replies. If you are interested, we can continue the discussion outside this post.
Cheers.
I am not interested in continuing this discussion elsewhere. Flooding the thread with better, or "correct" ways to achieve this, is quite the point of this conversation 😉
Message 15 of 16
davebYYPCU
Ah, I went for the quick and easy way, because your bowl / spline was as simple as it is, and punted on one loop.
Wrapping text (“Fusion 360”) to a donut shape, was done in other YouTube videos, (surprised none were referred to) incorporating lots of trickery and Sheetmetal Fold / Refold known as Wrapping. Fusion 360 - Curved Text - YouTube
For your question, was way too complicated to explain here for such a simple curve.
Might help.....
Message 16 of 16
davebYYPCU
Just checked your file, thank you,
So you used offset plane 2 more sketches, split the final ring, for some reason, leaving 3 bodies in the file, - I cannot see (more correct?) efficiency here.
See link in previous message for more correct?.
Might help....
