Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to use the Web Tool on cylinders
3 REPLIES 3
nick.jander
427 Views, 3 Replies
Hello there,
I am new to Fusion 360 so I am currently watching the Self-paced learning videos.
I wanted to recreate a model from the video Quick Tip - Sketch gems 3 in Advanced part modeling techniques (https://help.autodesk.com/view/fusion360/ENU/courses/AP-TIP-SKETCH-GEMS-3).
But I cannot figure out, how I could create the diagonal web/rib on the cylinder (see attachment). I tried several things with 3D splines and projections. The vertical ones are no problem though.
Thanks in advance for any ideas.
Tags (3)
3 REPLIES 3
I guess you mean the model of my cylinder right? I recreated the model again as the other one was clustered with failed sketches and projections.
Bunga777
in reply to: nick.jander
Sketch like this.
Use the EMBOSS command to create a concavity.
Fillets were added and copied in four directions.
