How to use different appearances for design and render without changing manually every time needed ?
CapGuy
CapGuy
When we use transparency for some materials and appearances, it could be painful to work on design since the "clear" look does not help to manipulate, design, and so on...
So I usually design with a "plastic" or "metal" generic material, then when I want render, I change the materials and appearances.
But you can understand with iterative design needs, it can become a pain to work like this...
So I wonder how to use different appearances for design and render without changing manually every time needed ?
Thank you for your time trying to help me,
Guy
May The Force be...yond !
g-andresen
Simply activate the Component Color Cycling in design mode.
günther
CapGuy
@g-andresen : simple and efficient, thank you very much.
BTW do you know how to choose and set the colors ?
Best,
Guy
g-andresen
It is not possible to select a color directly, you can only switch in the palette.
günther
