Hi @Anonymous,
You can do this inside Fusion 360 - in the Render workspace, you should see all of your rendered views in the gallery at the bottom of the window. By default these just render version 1 of the design, but by dragging these into the panel on the left-hand side, these renderings will be updated every time you save the model:
Note that you can add additonal render views to this list by either:
1. Adding a Named View to the model (change the view to match your desired viewing angle, then in the Browser, right-click Named Views and select New Named View)
2. Creating a cloud rendering with the Cloud Rendering command (this could be preferable to option 1 - this will 'remember' all Environment and Camera settings you changed in the Render workspace, whereas Named Views will only remember the camera direction)
Let us know if you hit any problems with this!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
