Hey, Fusion community!
This is definitely a beginner question which has been answered already, but I was not able to find that answer yet...
I'm making a box for a few components which will be placed inside this box and then can be accessed via cut-outs in the walls of the box, for example, a PCB with USB plugs which should be accessible from outside of the box to plug a connector. In the process of design, I do not know yet, where to place those components, but I would like to have cut-offs done on the walls to better see and decide the best positioning. In my design, I got a PCB with USB plugs inserted as an external component from another design. I placed it inside the box body and meanwhile placed it with a joint, since I thought it would resolve me problem. I projected the geometry of the plugs on a sketch on a plane at one of the walls of the box. The projected geometry is visible and I could create rectangles for cut-offs. Now, when I move the PCB to another position, the projected geometry stays on the old position. I would like to see it changing and so moving the cut-off automatically. I failed to find any controls where I can tell Fusion to update the projection... What am I missing?
PS. I hope I explained it well... It is my first post and I did not figure out yet how to post a screencast, so I added a simple screenshot for now.
Thanks!
