How to unwrap to flat from an STL
nkloski
nkloski
I have a client request where they have created a nice STL from a type of wire-mesh device that is:
  • made out of constant thickness wires
  • repeats in a 3D pattern (twists in Y as well as travels in X)
It is a more complex pattern than this, but it is a similar idea.  The area I am working on is just a cylindrical shape with no termination, to keep things simple:
Here is my thought process:
  • Import the STL
  • Do some painstaking spline-work (or maybe in Sculpt with snapping edges) to re-create the shape
  • Use the Sculpt--> Pipe command to make it all nice
  • Create a thick sheet metal cylinder around the shape, intersecting it
  • Boolean Subtract the pipes from the curved sheet metal
  • Unbend the sheet metal to a flat
Would that work?  Since I don't know sheet metal, I am unable to answer that.....but will "things" that happen to a curved sheet metal object, "flatten" out when unfolded?
Thanks!
Nick Kloski
davebYYPCU
Seeing the pic is not the real deal, and sizes are unknown, as long as it is a cylinder, or conical should work.
If it were me, I would make the cylinder unwrap it, the place the 2d knurling pattern on it, as indicated.
In the real world it takes some doing to roll thick sheetmetal.
My 2 cents....
TrippyLighting
As @davebYYPCU said, if the shape is a true cone or cylinder the sheet metal method works (I would love to have this available as a general modeling tool), but if is the cone has curvature then unwrapping that in Fusion 360 won't work.
