How to uniformly scale everything, with the planes for sketches
I'm trying to scale everything in my model uniformly, but when i use the normal scale uniform feature everything gets scaled oddly due to the planes not moving along with the surfaces I generated. Is there a way around this?
With this method, changing one User Parameter scales the entire model uniformly:
miguel.palma82
Hi @Anonymous
Remember that if you scale something, you should have a reference, in this case, your reference is your scketch.
Then, you can achieve a scale ratio of your model, taking the dimensions of your sketches as a reference,
I recommend you, simply make your sketch be in the final proportion you need,
Miguel Palma
Autodesk Student Ambassador
