how to un combine a body
I recently combined 3 bodies in to one and need to uncombine them. i am not able to roll back in my history as i have had that turned off. Any way to do this?
TrippyLighting
Nope, not in Fusion 360 as we don't have an untrim command.
However, if the model is simple enough maybe there's a way.
Can you share the model ?
jeff_strater
Split Body is usually the only way to "un combine" a solid body.  You can use a sketch or a surface body to split a solid body into two.
"i am not able to roll back in my history as i have had that turned off."  May I ask why?  If you want to do operations like un-do a combine, then history seems ideal.
Jeff Strater
Engineering Director
TheCADWhisperer
Depending on your geometry - you might be able to Unstitch and then Stitch desired bodies.
File>Export and then Attach your *.f3d file here.
Never, ever turn off Capture Design History without asking questions first.
Either you absolutely know that is the correct step, or it is almost certainly the incorrect step.
