how to swap inside/outside arrows of dimension?
2 REPLIES 2
ksAZ3XE
257 Views, 2 Replies
hi, I'm having some trouble where often Fusion confuses inside/outside measurements when dimensioning.. and I cannot figure out how to change or force it to show correctly...
I don't know if its related to how I drew the part in the first place, or its just the annotation that's confused..
i hope someone have some answers..
Labels (1)
2 REPLIES 2
TheCADWhisperer
in reply to: ksAZ3XE
I don’t understand the issue?
Exactly what is incorrect in the image that you attached?
Is the supposed to be a diameter symbol on the 60mm dimension - is that the issue?
Oh wait a minute - I think I see the issue.
You are simply looking for a toggle for flipping arrows inside or outside...
If I follow - you are looking for something similar to this image from Autodesk Inventor Professional...
ksAZ3XE
in reply to: TheCADWhisperer
yes exactly what i'm looking for!
i'm more used to inventor proffesional, and now trying to get the hang of fusion360 🙂
Technology Administrators
