How to split mesh
How to split mesh
chenhan5
1,069 次查看
12 条回复
1 条消息(共 13 条)
How to split mesh
chenhan5
Hey guys, I have this huge cluster of mesh bodies. I am hoping to split them into different parts rather than being a huge cluster. Does anyone know how can I achieve that?
0 个赞
1,070 次查看
12 条回复
回复 (12)
2 条消息(共 13 条)
jeff_strater
those look like mesh bodies.  I assume they show up in the Bodies folder.  If so, just right click on that folder and choose "Create Components From Bodies":
Jeff Strater
Engineering Director
3 条消息(共 13 条)
不适用
Not exactly. This program is a stutter. I accidentally  ended up doing this anyway. I guess this comes to the ability of comparing meshes, forms and bodies.
In mesh tool select generate face groups. Then select separate in the modify group. You get options. Mesh shells, select faces, select face groups, or just all face groups automatically.
This was ofcourse only beneficial to me. Because it was a scala model. And I had to repair the surface.
You're welcome. I'll attach a sample project. But, it's useless. I unfortunately do not have history recorded there. For some reason. It's missing.
0 个赞
4 条消息(共 13 条)
TheCADWhisperer
@Anonymous wrote:
This was of course only beneficial to me.
@Anonymous
Why do you attach useless files to old threads?
5 条消息(共 13 条)
不适用
you're twisting my words. it was a scala model. mesh objects opened with Fusion 360 don't capture history.
0 个赞
6 条消息(共 13 条)
不适用
not to mention this file is supposed to contain YBF/I texture maps.
0 个赞
7 条消息(共 13 条)
不适用
Why don't you impress the entire community. I forgot which file this is supposed to be. I'm pretty sure asteroid copy.
0 个赞
8 条消息(共 13 条)
TheCADWhisperer
@Anonymous wrote:
...mesh objects opened with Fusion 360 don't capture history.
@Anonymous
Works on my machine.
0 个赞
9 条消息(共 13 条)
TheCADWhisperer
You did not Attach the texture files?
0 个赞
10 条消息(共 13 条)
TheCADWhisperer
I am old and retired now (and probably forgotten half of what I once knew) - I don't need to impress anyone.
If you have a question - it would have been better to start a new discussion thread with a link back to this one for reference.
See Attached file of scanned obj file including textures.
(If it doesn't display properly on your machine - ask questions.
0 个赞
11 条消息(共 13 条)
不适用
Yet. you continue to double contradict your comments. How is any of that supposed to record history of the attached model.
0 个赞
12 条消息(共 13 条)
TheCADWhisperer
@Anonymous
See the Timeline.
First step - Enable Capture Design History
Step 2 Run Repair on the imported obj geometry. (Might not be necessary, but in any case, reading the Timeline we see that operation was performed).
Step 3 Run Remesh on the imported obj geometry. (Might not be necessary, but in any case, reading the Timeline we see that operation was performed).
Step 4 Run Reduce on the imported obj geometry. (Might not be necessary, but in any case, reading the Timeline we see that operation was performed).
Depending on Design Intent - the next step might be to convert from a mesh body to a solid body...
Do you see how the Timeline History can be followed using the Previous Step/Next Step play
or by simply dragging the playhead?
You can also right click (or double click) on any feature in the Timeline and select Edit Feature...
0 个赞
13 条消息(共 13 条)
laughingcreek
@Anonymous wrote:.... How is any of that supposed to record history of the attached model.
he's already answered that twice.  turn on "capture design history"-
0 个赞
