How to split a body into 2 bodies using 2 partial planes
DanGriffinSTA8Y
DanGriffinSTA8Y
I have body that I need to cut vertically and horizontally into two bodies.  I figured out how to do either a horizontal split or vertical split by itself, but doing a partial version of both at the same time escapes me.  I am a casual educational user.  A step by step guide should suffice.  Thank you.
TrippyLighting
See screencast:
TheCADWhisperer
@DanGriffinSTA8Y
For future reference,
DanGriffinSTA8Y
Thanks.  Worked fine of course.
jhackney1972
It is customary to select the “Accept Solution” icon on the Forum post that answers your question.  Please do so.
John Hackney, Retired
jhackney1972
You marked the wrong post as the solution, I switched for you.  @TrippyLighting gave you the solution that you said solved your issue.
