How to smooth fill gaps between bodies?
Hi there.
im really noob in fusion 360. Stared at monday and manage to draw this wings but from yesterday im stuck.
Im watch nearly all videos about loft etc but dont now how to connect them 2 bodies. loft should work but need to draw lines in that wings and dont now how to do it? line patch should be like my cursor going on video.
Any help will be would be apperciated.
TheCADWhisperer
Are your Sketches fully defined (turned dark color, probably black) and Push Pin image in browser?
Start with Sketch1.  If not fully defined - that is the time to start asking questions.
Are there any yellow or red highlighted unresolved issues in your Timeline?
That is the time to stop and ask questions - don't ignore these issues.
I recommend that beginners not use ANY splines until they have mastered line, arcs, circles and rectangles...
davebYYPCU
Change the Sketch37, to cover the half wing profile, modify the top view sketch to line up, the top view sketch Extrude cut needs to be 2 directions, fixes the rear version.
Front wing is moved after this sketch 37 is finished, (without its sketch) so you need to make Sketch 37 with the font wing where it has to be,
Follow the same steps as the rear is done.
Too many spline points in the sketches.  Less is best.
Might help...
