I'm trying to create two lofts that are mirrors of each other (yes, I know I can use the mirror command), but there seems to be a set direction the loft flows, so the second one ends up not looking anything like the first.
Here's my starting Sketch. I want two lofts - one from each pair of circles down to the rectangles:
So I create the loft on the right
Then create the loft on the left
You can see I use the exact same parameters, but they look VERY different.
Only when using the Mirror feature, can I get what I want:
So, is there a setting somewhere that I'm missing to set the Loft Direction? (I think that's the issue here), or is this something else entirely? Or am I stuck with using the Mirror feature to get lofts to do what I want?
Thanks!!!
