How to set custom template for 2d drawings
Harshal_Belan
Harshal_Belan
2d sketch supports ISO and ASME template format for drawing details. How customised template can be set for same?
scott.price
@Harshal_Belan -
With the July 28th release you can now create basic templates in Drawings - This option is in the Output panel of the Toolbar when you expand the flyout and creates a template from the current drawing.
At this time the template will save text, Title block attributes, any objects not associated to view geometry, as well as annotation and document settings - for reuse in new drawings.
Can you tell me a bit more about what details you'd like to be setting in your templates?
Scott
Hi
That was helpful.
However I would like to able to edit the title block or make a custom one for my students to use. Is there a way?
Mark
scott.price
HI @Anonymous -
We're shortly adding more flexibility with the Title block in drawings - while currently you are limited to the provided Title blocks, in the upcoming release you will be able to insert a DWG with Geometry, Text and Attributes as a Title block.
We'll be continuing to develop this but are hoping this release will serve as a first step in increased functionality.
Best,
Scott
Harshal_Belan
Hello Scott, Thanks for reply and making improvements. WR Harshal
